Forgive me if I break any rules but this is my first posting. I have searched for what I need but cant find anything so here goes.
So here is my problem. The stop cock no longer turns off the water even though its turning OK (and does reduce flow marginally) so I suspect the washer. I can turn it off in the street so Plan A is to do that and then take apart the stop cock and replace the washer. I know it probably wont come apart easily which is why I need plan B which is change the stop cock.
The house has a mixture of copper and plastic plumbing and some one has butchered it. The stop cock is copper one side into the system but the feed in is on a grey plastic pipe with a straight coupling to a short piece of copper on the stop cock.
This fitting is marked HBP 22 which I suspect is hepworth unless someone knows better and also that its not reusable but can be carefully removed?
So with pipe and fittings of that genre if I replace it with a modern Hepworth coupler (this is the mains feed in), what sort of pipe insert will fit this older pipe. Most importantly, is this a bad idea.
Either way I have to do something and am open to suggestions.
