heres another one!!! vokera combi
2 Jul 2003
not that im clawing at too many brains at once but heres another question..
I have a vokera combi boiler with no instructions (already here when we moved in) the water pressure from the hot tap leaves alot to be desired however the water that comes out is scolding hot, can i turn the pressure up in some way obviously loosing some heat (this can be afforded due to the current high temperature) yet increasing the supply rate.
and thats it, there you go.
cheers
Not familier with your model but it should have a isolateing valve at the mains water inlet. Remember that your water temp will be colder in the winter upto 17DEG C less than today. Check to see it is fully open.
cheers, there is, and i have sorted it now, thanks
