first of all have a round of virtual drinks or however you do it here
So down to buisness, I have a 3 bed semi with a seperate boiler and hot water tank that apears to be heated by hot water passing through a coiled pipe inside the tank.
the radiators apear to be fed from a grundfoss pump that is connected to a 3 way electronic valve ( see below)
now the problem I have is that with the rwb20 controller ( which I have tested and is known good) set to just hot water and not central heating I still get hot radiators.
However with the unit set on central heating only the boiler and grundfoss pump only fire up when there is demand from the thermostat ( i.e the temp is lower than that set on the stat)
There is a blue motorised valve that has 3 22mm pipes running to it one from the boiler the 2nd apears to feed the heater coil input of the tank and the third feeds the grundfoss pump which I assume feeds the radiators.
I have found that the motorised part pf the valve can be uncliped and the little tap it drives turns about 45degrees.
with the tap in the 45deg from horizontal position I seem to get no hot water to the coil in the tank but do get hot to the rad pipe with the tap in the horizontal position I get flow to both outputs.
also the grundfoss pump continues to run and I'm sure this isint pumping hot water round the coils in the tank.
This may have been an ongoing fault as we used to turn the induvidual rad stats down to keep the temp down but then I discoverd that the controller had seperate hot water and central heating outputs.
Any help would be apreciated as this is driving me up the wall
