Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
Looking for a smarter way to manage your heating this winter? We’ve been testing the new Aqara Radiator Thermostat W600 to see how quiet, accurate and easy it is to use around the home. Click here read our review.
How about if I switch off the CH and switch the Actuator with the CH actuator (they are the same P/N) and see if the boiler fires up to heat the water?
they are only held on to the valve with 2 screws and just lift off without having to disconnect any pipe work.
I'd go with Mr W's suggestion, for the sake of £5 buy the complete Honeywell valve. Appreciate you need to drain to fit it, but chances are it'll outlast a new actuator for the current valve. (You then have spares for the other valve! )
