Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
Looking for a smarter way to manage your heating this winter? We’ve been testing the new Aqara Radiator Thermostat W600 to see how quiet, accurate and easy it is to use around the home. Click here read our review.
we have had boiling radiators but no hot water
our heating is on a timer
pump is grundfoss UPS 15-60which is working but we are not getting no hot water
we do have a header tank in the loft also if the helps you :
on the valve for the hot water, move the lever to the manual position and latch it there. You should get hot water . If it wont move, it's stuck and the head will have to come off to do it. If it does move, you may need a new head.
yes it has worked do we leave this in this position forever now or is it still a problem to be looked at also will this still work ok with our normal settings on central heating and hot water ?
Don't leave it open for ever. There is a problem which should be fixed. It is probably the motor head. You can buy replacements, but I suggest you get someone to do it for you.
