- Joined
- 12 Dec 2005
- Messages
- 4
- Reaction score
- 0
- Country
I moved into my house in feb, and I have had problems with my boiler. I suspect I need a new one. I dont know nothing about plumbing so thats why I am here. Cheers for advice in advance.
1) Boiler make / model (gas or oil)
E.L.M Leblanc. Gas. Its a combi if that helps?
2) What is / is not happening
When I moved in the central heating would work but the main problem was with when you turned the hot water off after running the boiler used to cut out. Now the central heating does not work and you can only start the boiler by taking the casing off and lighting with a match. You can still light it even tho the boiler is turned off.
3) Has ANYTHING else been done / changed recently
Somebody tried cleaning the boiler but same problem.
4) When did it (problem) start
has gradually got worse since feb.
5) When does it happen? eg, heating coming on or going off
central heating doesnt work at all now. I can get the boiler on by taking the casing off..... but it will go out again once you turn a hot top off.
6) Anything else you feel may be of relevance
It looks like a very old boiler. and my friend who cleaned it out for me said I need a new system.
If you guys cant help, What system would you recommend? Hopefully cheap as I seriously cant afford it as it is lol. Cheers again peeps
