HiFlow 400
5 Jan 2012
Worcestershire
Hi All, I have a Worcs HiFlow 400 it's 10years+ old and the Hi Temp trip keeps dropping out when using the shower. I think it may be a flow issue. Also the CH loses pressure but I can't find a leak anywhere? Any ideas please. :(
could be quite a few things wrong with it. check you'r blow off pipe outside for leaking. check to see what pressure your gauge gets up to on ch. usually just a screw on the expansion vessel. and it should fall towards you with the front control panel pulled out a little. the EV should feel quite light. if it feels heavy then it either needs recharging or is kaput. most i see on these are kaput. better still get a worcester fixed price repair. these can be a pita to work on.
Thanks for that, I will check later. I have been told that there is a filter in the incoming that could be blocked or the Heat Exchanger is furred up. What is your experience of this? Also I changed the CH pump 1 year ago.
DHW tripping is often the filter or DHW heatex blocked.
Checking the filter is not too difficult but a pain depending on access. If its the heatex then it's a costly business.
Worcester may be your best option.
Your best bet would be to get Worcester out. The manifolds inside these boilers are a real pig and leaks spring up everywhere when you work on them.
The newer versions are much better thankfully.
Hi All, I went outside this morning and water is coming out of the blowoff pipe. Is this why the CH loses pressure?
Yes, you will need a new expansion vessel - and probably a new pressure relief valve, as the old one will be disinclined to reseal unless you are v.lucky.
