high temp masonry paint?
13 Dec 2011
Cumberland
having just installed my wood stove i am now getting around to decorating the fireplace area,
i need to find some black high temp masonry paint to paint the brick work around the stove but im struggling!
would stove paint work??
anyone have any suggestions
sorry if this is in the wrong area, please feel free to move if required mods.
I know nothing of paints, but traditional "Stove Black" ( used to clean the old fireplace CI ranges ) might do the trick.
Rustins do a high heat resitant matt paint which I've used on a couple of barbecues and it gives a similar looking finish to your stove. The tin says it is suitable for most surfaces, but not having used it on a masonry, I can't really say how well it would work.
The problem is that it only comes in small tins, meaning you will probably need a few to do the job you want. :(
http://www.transtools.co.uk/store/p...ing-matt-black-paint-600-degrees-c-500ml.html
Hi Richard,
Have you used the Vitcas paint in your link? If so, do you know if it is available in various colours or can be tinted as I can't seem to get much info on it through the Vitcas site? (I've tried the online shop link but maybe I'm looking in the wrong place :confused: )
It would be a great product to recommend to clients if it is available in a range of colours.
Cheers,
mrH :)
Hi MRH
No I haven’t used it, only product I’ve used of theirs is the heatproof plaster. For render base, I use a sand/cement/lime render in two coats which hasn’t failed me yet.
The tub paint only seems to come in white but the spray comes in black, white, cream, silver and red. TBH I think bog standard emulsion is probably good enough for all but the fire opening (& possibly even there) but I’ve not been abe to find any info on heat resistance; I’ve never had any fail on the wall around an opening.
Hi all.
Thanks for the replies and input.
I have used ordinary exterior masonry paint so I will update later and let you know of any issues.
Hopefully none.
250ml tester pot done one coat!! = £2.50
Please excuse the tiles as I am just grouting them!
That's what I tend to think as well but I'm always dubious about recommending it 'just in case'. I've used emulsion on jobs where I've been asked to and it's generally ok but has sometimes become brittle and does discolour. However, it's not a situation I encounter regularly as most people with this type of fire in my neck of the woods tend to leave the brick/stonework in it's original condition or have it finished as part of the installation.
Thanks for the reply. :D
@ Chops77
It doesn't look bad so hopefully it will stand the test of time.
Keep us informed! ;)
Think the white grout was a mistake; it won't look like that for long & it tends to crack & fall out. I lay the tiles with ½mm gap & fill with clear silicone.
The tiles don't get the slightest bit warm do I can't see the heat affecting the grout!!
These two paints will do the job and have used them myself to paint inside my stove alcove onto cement particle board.
Themacure Heat Resistant Paint - very smelly but good adhesion to cement board, render and brick. Not thick, but easy to apply. Also can paint stove.
Fascinating Finishes Heat Resistant Wall Paint - comes in different colours very good covering paint and it works on the same materials as above. Ps do not paint the stove in this one though.
Had very high heat on both to test them and no blistering.
