hi
I currently have a high pressure problem in my highflow 400 electronic boiler. It's running at 3 bar which triggers the PRV so I got constant dripping water ( and I'm on a water meter).
Plumber has come up and he changed the expansion tank, but the next day pressure was back up. He's changed the heat exchanger and the problem still exists. Isolated the filling loop and again the problem is still there.
The system has been drained and repressurised, radiators been bled and I'm still having the same issue. Soon as the cold water feed supply is turned on this is when the pressure goes up high.
My plumber reckons it's mixing somewhere forcing the pressure up. He has spoken to worchester to see if they have any ideas to what it could be, and they are stumped. The plumber can only think of two other places where this problem could be and this is the top and bottom manifolds where the heat exchanger is attached to, these are the only place the water could mix if there's a crack or leak in there.
Worchester said they have never had a problem with any of their manifolds, but I suppose there's always a first time.
Can anyone else think where else the issue may be. When the boilers off the dripping water is cold, soon as the central heating is on the dripping water becomes very hot
