I recently moved house and have been gradually been rectifying various electrical oddities that I've come across. This weekends job was sorting out an outside light (500w PIR floodlight)
The previous owner had wired the light into a bedroom ceiling rose with 1mm twin and earth. Since there appears to be rather a lot on this lighting circuit I've followed advice I've previously read on this forum and rewired it to a switched fcu on a spur from a socket in the bedroom and fitted a 3 amp fuse. This runs via 1.5mm cable to a junction box in the loft to connect to the 1mm cable coming from the outside light.
My remaining problem is that the cable running to the ouside light is normal 1mm twin and earth. It goes through a hole in the wall and then into the outside light, meaning that about 12 inches of the twin and earth cable is exposed to the elements which from my reading of the forums is not allowed. What's my best bet? Replace the 1mm twin and earth with 1.5mm hituf cable and terminate it in the junction box I've put in the loft? My main concern is that the TLC web site lists 11mm cable clips for use with the hituf cable which presumably means its fairly chunky stuff.
So the main question is how chunky is the hituf cable and is it going to be easy to terminate it in a 20amp junction box?
Any advice gratefully received!
