Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
Looking for a smarter way to manage your heating this winter? We’ve been testing the new Aqara Radiator Thermostat W600 to see how quiet, accurate and easy it is to use around the home. Click here read our review.
I am having the same problem my hive receiver fires up but the boiler does not respond. My boiler is a Worcester Greenstar 30si. Can anyone help please
The Worcester Greenstar range has changed over the years, the early models could only be switched off/on latter they had there own special thermostat think it was called Wave which connected to the ebus.
The same applies with Hive, there is a single and twin channel model and early versions would not connect to TRV heads with the heat on demand function.
However the most likely is it is a single channel Hive and you have not fitted the link wire, but photos are always good, I remember things that would not work for me, like car would not start, and the problem was so simple, I had not put gear selector into park, unlikely anyone on a forum would have considered such a simple problem.
