Hive Thermostat Wiring Assistance
Here you go:
This is for controlling the heating and hot water via the hive. With your current setup, your thermostat calls for heat but the hot water timings will be done via your programmer. If you want to have that control via the hive, it's going to be a little bit more complicated and we'll need the wiring of the programmer as well.
Ok, what I would do is replace your programmer with the hive receiver. It needs to be a dual channel receiver which from the screwfix picture looks like it is.
Wiring as follows :
Red - Live
Blue - Neutral
Green yellow - Earth
Orange - 1
Yellow - 3
White - 4
Then inside your wiring centre, disconnect the room stat cable and remove. Link the white core from the programmer terminal with the bottom terminal of the room stat (currently with the yellow core terminated)
Wiring as follows :
Red - Live
Blue - Neutral
Orange - 1
Yellow - 3
White - 4
Thanks lots.
So just to confirm:
All 4 wires out of ROOM STAT. Move white wire (third along) from PROGRAMMER, and put into where the yellow wire was in ROOM STAT (fourth wire down).
Is that correct?
Thanks lots.
So just to confirm:
Is that correct?
No, remove wires out of room stat, leave programmer wires where they are. Do as countryfan suggests and add a link wire between 1 and 3 on the room stat. (where yellow and red are currently)
Cheers buddy. Got halfway, quick pub trip, and two pints later, back to the wiring and all working perfectly. Absolute star. Thanks so much!
