I have a Bosch free standing electric cooker including four hob plates.
Now I have a problem: one of the hotplates has stopped working completely – the check light has gone out and the plate generates no heat whatsoever.
Two of the remaining hot plates continue to work, but each only works when the knob for the other is turned on. Almost as if they were wired in series?
The fourth hot plate, I don’t know whether it works or not cos the knob fell ages ago.
The oven works too, but on what appears to be reduced power, and it only runs when the switches for the hobs are turned on.
My instruction manual, tantalisingly, says before calling a service engineer out, the prob may just be a “trifle” and says to do a “thorough check on the fuses for the hobs”.
But it gives absolutely no info on where to find these fuses. I’ve taken the back and the front of the cooker off and I can’t find anything that looks to me like a fuse.
NB I am in Germany, although can’t see that would make much difference.
Thanks guys.
Thanks guys.
