    Dismiss Notice
Hole cutter extension bar to cut hole in 110mm soil pipe.
Discussion in 'Plumbing and Central Heating' started by Gerorge Standers, 30 Jul 2017.
  1. Gerorge Standers
    Gerorge Standers
    23 Jul 2017
    32
    Thanks Received:
    Country:
    I need to cut a ~56mm hole into a 110mm soil pipe, but need a drill extension (about 300mm ) to reach the pipe. Can anyone recommend products to do this?
    Dave
  2. Sponsored Links
  3. Gerorge Standers
    Gerorge Standers
    23 Jul 2017
    32
    Thanks Received:
    Country:
    The reason I ask is because I have bought a 56mm hole cutter, but the only arbour I could find for it has a wide (1/4"?) shank (not sure I'm using correct terminology, but the bit that gets tightened into the drill chuck) and I can only find extensions which fit the small size. I can find hole cutters which use a small arbour but they all seem to go from 51mm to 61mm and can't find one that's 56mm (ideally I need 54mm) with a small size arbour.
  4. Roger928
    Roger928
    10 Aug 2016
    2,631
    Thanks Received:
    201
    Country:
    One of these..
    [​IMG]
    12" extension shank...
    Have three of these in my tool kit
  5. Gerorge Standers
    Gerorge Standers
    23 Jul 2017
    32
    Thanks Received:
    Country:
    Thanks, looks reasonable - do you have link to one so I can check out the details? How does the hole cutter shank get secured, does it just rest in there? the one I have at the moment has allen key grub screws to secure it but only accepts a small diameter 'shank'?
  6. Sponsored Links
  7. Gerorge Standers
    Gerorge Standers
    23 Jul 2017
    32
    Thanks Received:
    Country:
  8. PullerGas
    PullerGas
    11 Jul 2015
    6,062
    Thanks Received:
    1,205
    Glasgow
    Country:
    Sort of begs the question; if you need an extension that long are you going to get into the pipe to fit the boss?
    • Like Like x 1
  9. oilboffin
    oilboffin
    26 Apr 2011
    1,665
    Thanks Received:
    247
    isle of Lewis
    Country:
    My thoUghts exactly sir dick now I'm back on my feet.Bob
  10. Gerorge Standers
    Gerorge Standers
    23 Jul 2017
    32
    Thanks Received:
    Country:
    It's a boxed in internal soil pipe on the inside of an exterior wall. Having removed some plasterboard, I have good access to the part of the pipe facing the room, and enough space to wrap a boss around it and apply solvent weld to the part of the pipe facing the exterior wall, but obviously not enough to cut a hole through it. I'll have to do that through the exterior wall, hence the need for the extension.
  11. DIYnot Local
    3 Sep 2019
    Country:
Loading...
Share This Page
