What size hole do you generally core the hole for a toilet waste so it accepts the collar of the waste fitting. The same for a 40mm waste pipe, so it attempts the collar of the fitting. Thanks
Same again, are you talking about the female end of a fitting
All you need to do it measure their diameter? A solvent weld pipe is 43mm and the diameter of the fittings are around 48mm but you'd want the hole a little larger to give some wiggle room.
