Holland ikea induction plate
14 Aug 2012
Morning guys,
I have a cooking induction plate here in Holland, the old wiring was blue l1, brown l2, black l3, black N & earth.
The new connections I'm told to use are l1, l2, N & N & earth. I'm assuming the two black cables are N & N does that sound right?
If its wrong what could happen?
Thanks for your time,
Jim
original oven connection, bottom right is L3 black, bottom left is N black.
new
No!!!!!
Do not connect your cooker as you propose! It will cause a short circuit, and do all sorts of bad things.
I'm not familiar with your country's wiring practices, so first question is where does the other end of that cable connect to? Is there a local isolator near by for the cooker?
Do you own a multimeter?
I love your username by the way!!
Hi, thanks for the reply, I will be getting a qualified electrician to look at it.
