Home Automation bumblers
27 Aug 2003
London
From http://www.vesternet.com/z-wave-aeon-labs-heavy-duty-switch#tabbed-qa
Because as everyone knows, cookers are controlled by simply turning the power on and off - fortunately no cooker makers have thought to require any buttons to be pressed or knobs to be turned in case blindly starting up after a power cut might be dangerous.
Some cookers require the clock to be set to the correct time before any element can be energised. So after a power cut the cooker will require the clock to be manually reset before any heat can be produced.
EDIT having checked on my Neff.... the clock has to be set to any time and not necessarily the actual time. While the clock display is flashing 0:00 only the cooling fans will operate.
I suppose that's inevitable, since knowing what the "actual time" was would require a degree of sophistication and complexity unlikley to be found in a cooker! However, it serves the purpose by requiring some manual action before the cooker will work.
Kind Regards, John
One would hope that no cooker younger than {insert quite an old age} could be left on at the controls and start up when power is applied - it really could be lethally dangerous.
What!?!
You mean an appliance industry which has given us fridges with web browsers hasn't managed to make a cooker which supports NTP? What's wrong with them?
What!?! You mean an appliance industry which has given us fridges with web browsers hasn't managed to make a cooker which supports NTP? What's wrong with them?
I suspect that they are just being sensible, and therefore not including functionality/cost for which there really is not any demand (or 'need')..
Kind Regards, John
I know all my ovens need the time set, and my single stand alone hob will not start without pressing the on button then second button, not sure about stand alone cooker however it needs to have some thing which is attracted by a magnet so unless pan also left on the hob nothing would happen, it also has over temperature sensors so there is a limit, since it locks out if left on without a pan until you switch the ring off and back on again I suspect if switched on with a ring switched on it would auto lock out that ring until turned off and on again, but not at home so can't test.
However I am sure there are cheap and nasty cookers made with little or no safety features, eldest daughter and father-in-law has cookers with naked flames and you can still use a standard pan to heat oil or fat, that must be extremely dangerous, people use to these antiquated hobs have got use to treating them with extreme caution, however those use to using electric induction hobs have over the years got use to the safety features.
I walked into my caravan to see the gas hob burning, not easy in strong sun light to see the flame, it seems my wife forgot to turn it off, at home she did not need to turn it off, the hob would automaticity do that.
This is the problem with any safety feature, people get use to it being there, so once we start to add them we have to continue using the feature and expand it to other items, when I was a lad there were no RCD's but today they are fitted to all new houses. As to hobs first I used had a spring like element which was wound around a porcelain former, over time the spring would break and often the ends would spring up and touch the pan, you needed pans with plastic or bone handles or you could get quite a shock, easy to replace Woolworths sold them in little packets. Today no one would use these hobs, but they were common.
