- Joined
- 27 Jan 2008
- Messages
- 29,636
- Reaction score
- 3,663
- Location
- Llanfair Caereinion, Nr Welshpool
- Country
I will admit swing top bottles are the best, they will auto release any over pressure, I have a few glass bottles with swing tops, as yet not used, but with pop bottles one can squeeze the bottle and get an idea if going over pressure without needed to release pressure.
I found with old fridge which I had intended to use in same way as box you have built, ambient temperature needed to be lower than 10°C not to over heat on start, I did consider leaving door of fridge open for first few days, but how to monitor was a problem.
So by monitoring power used by heat plate
I know 25 watt when full on so if under 25 watt it is switching off/on so warm enough, but I do not watch the fermenter so it is hard to know if it over heats other than a zero power use.
It does not heat up fast, so set to 19°C with max of around 24°C before the brew becomes very bitter with an after taste, in the main it is OK, but only 100% method involves cooling.
However if it does over heat, then storing for a long time does improve the taste and get rid of a lot of the after taste. However what I want is set up and forget, I want to do the transfer, bottling etc when I have free time, not when the hydrometer says I should, and with the energy monitor I was able to check my brew even when in hospital. Not that I could have done anything if it went wrong.
