Honeywell Accenta G4 Compatible with Ademco 983 iner sensors
27 Dec 2011
Renfrewshire
Bought a replacement Panel to replace old one which I previous owner installed. "Had no way to change code"
I have many sensors on windows which still work well. I must have about least 30 sensors (on 4 wire cable)
Will these sensors work with this panel as I am not being successful so far. The old panel had additional circuit boards.
Do I need to configure in a special way or purchase additional equipment
You from the sound of it have a ID system, is there a small "chip" in the detectors or in a junction box near them?
With 3 wires red blue and white.
If so you need a ID panel.
What was the old panel, might be easier to actually get the codes changed.
Was it a Castle or a Menvier?
There was no name on old panel so very difficult to identify. Panel was acting up and proved fault was to Panel hence need a new panel
Well if you have 30 devices you have a ID panel.
You need a Texecom or Castle of a Menvier panel ( thats if Menvier still do one!)
the other board within the old panel, was it connected to the initia sensors?
if so it could be the analiser board
if you dont have that in place the sensors will not work
but again you could have an ID biscuit system as is posted above, (hate em with a passion!!)
Oasis
the ademco 983 is an inertia crossbar sensor(most basic) and will need an analyzer board if you have thrown away the old one, you can still get hold of an aritech single or double analyzer board from adi . GS614/15/17
I think you meant that the 980 & 981 are the most basic, the 983, the crossbar sensor is the 2nd generation of inertia detector, otherwise you are correct.
Ahhh the inertias.
Those puppies.
As said you need an analayser, or change the baskets.
Not going to give you zone descriptors.
