Honeywell Accenta G4 Program Selection
4 May 2017
Hi all
I'm new to this site.
I have just fitted the above system and during testing I find that I can't access programmes 2 or 3 when setting the system. I enter the code followed by 'P' but the exit tone doesn't stop, and I can't select program 2 or 3 Any ideas?
D
Doggit
When you say you you press P, I assume you mean the prog key. And I've got to assume that you programmed the zones for each part set program, and that you've checked them.
4 May 2017
Hi Doggit
Yes that's correct. P is the Program key and I had programmed zones 2 & 3. Program 2 is a part set and Program 3 has a different exit zone.
However, your reply has prompted me to double check programmes 2 & 3 and I've discovered that I had the exit modes set to disabled. Having set them to timed it's working correctly now - Doh!!
Many thanks for your reply.
D
Doggit
Been there, done it, felt the same. Best of luck.
PS, have you spotted that the Accenta can handle fire alarms on zone 7&8
4 May 2017
Cheers Doggit. Yes, I was aware of potential for fire alarm on zones 7&8 but have used them as security zones.
All the best and thanks again.
