Hoping someone can help.
I have a Honeywell Galaxy Dimension GD-48. I am wanting to add a keypad into our garage which will make 4 in total on the system.
The spec for the system is 8 non keyprox, 3 keyprox (says 8 and then 3 in brackets). It doesn't say if this is either / and / or though! Honeywell support don't seem sure either which seemed a bit strange as it can't be that uncommon. Our local installer seems pretty sure it should take a mix of keyprox and non keyprox (3 keyprox and then 1 more non-keyprox) but can't get it to address the keypad. I've lost faith a bit and can't believe there is not a definitive answer to how this works.
I'm thinking problem is that I have keyprox ones already and it can't take a mix like this? i.e. it can take up to 8 as long as ever one is non-keyprox. So if I swap out the keyprox ones for non-keyprox it should work (as we have less than
. I only use a code anyway.
I currently have v7 keypad and if buying new ones anyway was going to just get v8 ones. Anyone know if v7 and v8 are pretty much interchangeable - I.e. just a cosmetic thing?
Appreciate a bit if a specific one but any help appreciated.
