Honeywell Galaxy Flex Disable PIR
17 Mar 2015
Hi all
A year on since installing this system we are having a bit more work done on the house and i need to disable one wired PIR on my system. It's above a door currently and not quite working correctly so i have installed an RF portal and a door sensor instead which will work much better for us. My question is can i omit the PIR permanently in the system or do i need to disconnect it from the PCB? I read that you can leave it connected but put a resistor across the terminals so it never triggers, is that correct?
Mat
