    Dismiss Notice
Honeywell galaxy won't full set.
Discussion in 'Alarms, CCTV & Telephones' started by Jacobpem, 5 May 2020.
  1. Jacobpem
    Jacobpem
    5 May 2020
    4
    Thanks Received:
    Country:
    hello I have a honeywell galaxy 2-12 I got from ebay I managed to load defaults and restore the system to when it came from the factory. When I try to full set the system there is no countdown and the bar never goes down. Could any expert tell me whats wrong? Meny thanks!
  2. Sponsored Links
  3. sparkymarka
    sparkymarka
    16 Feb 2011
    7,991
    Thanks Received:
    1,210
    Sheffield
    Country:
    Its probably set to either final door set or exit terminate setting instead of timed setting
  4. Jacobpem
    Jacobpem
    5 May 2020
    4
    Thanks Received:
    Country:
    Thanks! I'm quite new to all this how would I change that?
  5. Jacobpem
    Jacobpem
    5 May 2020
    4
    Thanks Received:
    Country:
    Oh dear I'm stupid I never setup the exit delay lol got a new problem tho when disarming it allways shows that there was a intruder on the zone that was triggerd how do I stop this from saying that? Meny thanks once again.
  6. Steve Loveday
    Steve Loveday
    4 May 2020
    11
    Thanks Received:
    Country:
    Isn't that cleared when you first put your code in after.
    I think when you put your code in to stop the alarm you scroll though them and then ENT to continue.
    I'm still going through all my settings so not fully up to speed also.
  7. GalaxyGuy
    GalaxyGuy
    7 Jan 2014
    721
    Thanks Received:
    120
    Fife
    Country:
    Do you mean that you are triggering an intruder every time you come in and disarm the system ? You will need to set your entry door as a 'Final' zone. Any sensors on the way to the panel can be set as 'Exit' zones.
  8. Jacobpem
    Jacobpem
    5 May 2020
    4
    Thanks Received:
    Country:
    ah thank you GalaxyGuy I've got it all sorted now and working fully. thanks again!
  9. Sponsored Links
Loading...
Share This Page
