Hi all, I've looked at all the other HCW80 / HC60NG problems - mines a bit different, I hope you can help...
When the room is up to tempereature, the HC60NG reciever switches the boiler off. Then 10mins later it switches the boiler on for 2mins. Then 10mins later it does it again...(and repeat!)
If i turn the thermostat up to 30 the heating stays on - i haven't waited till the room gets that hot. If i turn the thermostat down to 10 the heating stays off - it only does the 10min cycle when the room is at the set temperature ie room at 20, thermostat at 20.
When it does its 10min thing, the LED does not light on the HCW80 thermostat, just the green light on the HC60NG reciever.
I have turned off all other wireless electronics in the house to check for rogue signal (wireless internet, phones etc, even the tv remotes!)
This was fitted last week, i will be getting the installer back, but I wanted to check that its not supposed to do that, and that hopefully I could tell them what to look for - this will be their 5th visit due to tracing a fault with the old Boss units.
Thank you for any help you can give,
Pat
Pat
