honeywell keypad
7 Aug 2011
Lancashire
hi there in the progress of replaceing a new keypad and alarm box the keypad i bought was an 8EP416-EU and the alarm box connect AG6 to Optima Compact GEN4, did the keypad the same as it was before then the box soon as i connect power the alarm went off put in the code alarm stop then that was it,
on the keypad i showed a spanner with the a red light on contacted honeywell they said there a fault with the tamp , so i took it down taken it back replace it and again am i doing some thing wrong.
Close the lid on the keypad and the control box and try again.
Then go around all the other devices and check them for tampers.
Also in a spare moment actually read the manual.
hi alarm reference the manual there wasent any that came with the keypad if when they exchange it this afternoon they did not give any with to do with the spanner on the box that what honeywell tech told me with the light on there a fault with the tamp
Tamper circuits are on the keypad the main panel the external sounder and the devices themselves.
I was refering to the manual for the panel, the keypad one is just a bit of A4 paper folded.
I was refering to the manual for the panel, the keypad one is just a bit of 14 paper folded.
the panel i dont have as it quite a few old i checked the panel all the connection are correct as i have not touched them, on the panel i only took out the live wire and the fuse which are back inside , the keypad there was nothing with it looked on the net there nothing i can see
Well I have said check ALL tampers.
But the RKP may be wrong anyway.
Check ALL tampers with a multi meter, that way WE ARE NOT GUESSING.
ok will try tmr
check tamp all ok now getting confused being told to try this
ST- = yellow
R- = white
SW = black
V+ =red
V- =green
at panel
STrobe + nothing on a newaccenta or optima
STrobe - =yellow
SCB = T = white
SCB =A = green
BELL + D= red
BELL - B = black
Something doesnt look right there. I think you have your black and white crossed over, but the labels aren't very clear tbh, bit too ambiguous.
Dont recognise the labels but if I had to plump for an educated guess I would go as follows.
ST-, yellow goes to STROBE-
R-, white goes to B-
SW, black goes to SCB T
V+, red goes to B+
V-, green goes to SCB A
V+, red goes to B+
this is what i was told to do
Panel AG6
T...... R
A..... V-
ST-..... ST
D..... V+
B..... SW
which meant i did
st - green
r red
sw - white
v+ yellow
v- black
i have upload picture to see if i am correct or not
V+, red goes to B+
Panel AG6
T...... R
A..... V-
ST-..... ST
D..... V+
B..... SW
which meant i did
st - green
r red
sw - white
v+ yellow
v- black
View media item 36722 View media item 36723 View media item 36724
