Can any one help? I have just had fitted a new boiler with a programmable thermostat. I am not convinced that it has been wired correctly. When the thermostat reaches temperature it turns OFF the CH valve and goes via the pump overrun pipe work. Surely the boiler should just turn off its gas heating and the central heating pump run normally and the CH motorized valve stay open. At the moment the poor CH valve is activate every time the thermostat clicks on or off. Is this correct? Thanks Spike123
