Fixed, just about.
In the process of fixing the controller to the wall, a wire sheared off in the wall, so the live feed from the controller to the boiler was broken.
Took a while for the engineer to work that out, as everything everywhere looked OK. He managed to pull just enough cable down to get it connected again, but said only about 3mm is in the connection, and if the controller gets knocked it will probably knock it out.
So for now, I need to be careful, and should be OK (it should not be knocked, although I do need to build a cupboard next to it soon...)
If it fails again as knocking it becomes a problem I cannot foresee, then a wireless Hive system would save having to replace the cable.
