Honeywell ST6400C - keeps turning off immediately
12 Jun 2011
Norfolk
Hi
I have an oil fired boiler with the honeywell st6400c controller
When I press the extra hour button to get just a hour of heat in evening it turns on then immediately off again, if I keep pressing it, eventually it will stay on
Any thoughts please?
Replace your faulty programmer.
didn't know the controller was the cause, hence me asking!
So I assume you think that is the cause? it is 2 channel and the hot water program works fine, so could just 1 of the channels fail like that?
Any tips on replacement would be handy
I have the same problem in which the 6400C cannot switch on the heating but controls the hot water perfectly.
I am planning to replace it with an ST9400C. I understand the 9400 fits on to the same wiring backplate. Is there anything I should look out for in the replacement?
hi nickpat
I replaced mine with the st9400c too - and it works really well now - just remember to make note of any "engineers" settings on the old controller - so yout can set the new controller the same - things such as cycle rate etc
And yes it does fit onto same back plate, just two screws, clip old one off and put new one on - put screws back and it works
