- Joined
- 11 Apr 2022
- Messages
- 1,009
- Reaction score
- 222
- Country
I have a Honeywell T3 programmable thermostat which has been installed for 3 weeks as a replacement for an older mechanical thermostat. I understand that the T3 is a TPI thermostat and I understand how that works but this particular thermostats operation makes no sense. In the morning the T3 calls for heat, the boiler fires up and the house warms up fine, the T3 goes into TPI mode when it detects its getting close to the required temperature so all good.
In the late afternoon the house is normally already at the required temperature so the boiler doesn't fire up however as the house cools the T3 still thinks the temperature is OK so we adjust the target temperature from 22 to 23 resulting in the boiler firing up but only for 1 minute or so before we hear the T3 click and the boiler goes off. The T3 does this boiler on, boiler off cycle every 10 mins or so but never gives the boiler the chance to heat the water as the radiators are still cold. This seems to me to be a waste of energy and doesn't result in the house warming up. What am I missing?
