This morning when i turned the machine on it was showing spin cycle and 7 minutes to go. Tried turning it off but no change so just left it to finish but a minute later a few fuses went in the main circuit board. Sorted that then tried again and everything appeared ok. I put a load in and it took in the first load of water then nothing. The digital panel at the front appears to be going through the cycle as normal but nothing is actually happening. Does anyone know what the problem is and also would it be expensive to fix?
Latest update is i let it run to the end of the cycle just to see what would happen and it's draining and filling up but that's it.
