Hi
Wondering if anyone can help me and my washing machine?
I have a hoover AC90 washing machine and tonight when it was on a normal cycle it stopped draining so i disconnected power and water and took the waste pipe off cleaned it out and put it back and took another pipe off from the bottom of the drum to the waste pipe took it off and found a 10p and a 5p problem solved I thought alas no it isnt!
Now when i go to select the program, nothing happens, if you turn round it stops between 10 and 11 and starts spinning for a while and then stops again no water is drawn into the machine and yes the water is definitely turned on.
Can anyone help me ??
