My tumble dryer is not spinning. This happened after we moved the unit to a new position.
The barrel was touching the side walls and managed to pry them apart.
The motor is working but it's not gripping the belt.
When I manually rotate the fan in the opposite direction the barrel moves, however when the fan is rotated the spin direction then the barrel does not move.
Is the barrel out of position or the belt is slack and if so how do I fix it. At the back of the motor I see a pulley, the shaft of the motor and a spring to the base of the unit.
Please help
Please help
