Hi
I am trying to repair a friend's Hoover Performa 1100 washer/dryer. The main drive belt will not stay on the drum pulley. It slips off the edge nearer to the drum (i.e. the edge away from you when working from the back of the machine), even when just pushing the drum round by hand. The bearings on both the drum and motor feel OK, the belt doesn't look particularly worn and I've tried using several positions on the lower, motor pulley. The drum pulley is slightly tapered with the larger diameter at the drum edge, but it's not much of a taper.
Is there any alignment adjuster on the motor, or is there another known fault on this model?
Thank you in anticipation
