Hoover fridge freezer HNMF 2805A L-80
7 Mar 2007
Cambridge
I have a problem with the above fridge where the fridge ices up for a few days then returns to normal then freezes up again, so whats the problem?
help
What number do you have the thermostat set to? It may be faulty if you have it on to your normal setting.
its down to setting 1 now, i found a big clump of ice on the left hand track leading down to the hole to the compressor.
help.
You won't find a diagram for any appliance. Under the ice block is the insulation wall damaged ie split on the wall
no cracks or splits in the back wall, it seems strange that it goes from frosty to normal which would sujest its a pcb problem not a stat prob?
