Hoover performa filter?
16 Feb 2008
Yorkshire
Is there a fluff filter on these? Mine takes AGES to do the drying cycle - 4 hours plus..
If it's the same as ours it could be because you have the condenser unit in upside down. My took wife this unit out (its the bit directly above the water tank) to clean it and ignored the TWO RED ARROWS point up and put it in the wrong way round (it is not a force fit).
If the condenser is in the correct way then it might be that that the heater element has died. I think we are now in this situation, as all filters are clean, the filter warning light is still on, yet it does not blow warm air. Built in obsolescence me think!!!!
Good Luck
Thanks for that - I've nor worked on this myself but I know others have. I'll check it!
The washer also makes a VERY loud buzzing noise on the drying cycle....
Chris
