Hoover washer dryer leaking from front corner underneath the waste disposal
3 Nov 2023
My hoover washer/dryer is leaking water from the front corner underneath the machine. I've cleaned out the waste disposal which was clean , but water is still coming out.
A favorite, is the pressure your mains water supply, being too high - it splashes out of the soap drawer, try turning the water valve down a little. Failing that....
You need to check for the leak, with the machine in operation. What I would do, is to stand the machine on a pair of milk, beer crates, etc., so I could spot where the water was leaking from.
Water is defo come from underneath machine
The only way, is to take a look and find the source. I jack mine up with bits of timber - tilt over, pack up with timber, then do the same to the other side. Back and forth, adding timber, until you can slide mild crates under. Then, run the machine, whilst you check underneath for the point of leakage.
