Hoping someone can help - Trevi CTV mixer too cold!
10 Dec 2009
Aberdeenshire
Hi, as above - I have a Trevi CTV shower mixer, recently the shower isn`t going quite hot enough. With help from the internet I`ve managed to take it apart and found the black plastic `H`for increasing the maximum temperature (unfortunately it was already on maximum temp!).
Is there anything else I should check? My next step was going to be to take off the check valve covers and make sure I`m not losing hot water into the cold side....I`m possibly grasping at straws here (I undersatnd I`ll need to isolate my water feed before this though!)
Also was going to check the strainer was clear.
Any help appreciated, Cheers!
£120 (ish!), *******s!
I`ve got all of the other parts off except the cartridge so I`m guessing it should be easy enough for me to do on my own? Not at home at the moment so can`t quite picture it...
Is the water from the hot taps up to temperature? May be hot water issue not a shower issue.
Thanks for reply. Yes the hot water from all other taps, including the sink next to the offending shower, are all providing hot water.
