- Joined
- 27 Jan 2008
- Messages
- 27,515
- Reaction score
- 3,325
- Location
- Llanfair Caereinion, Nr Welshpool
- Country
I have a problem in there seems to be nothing to say if the two parts are out of range or simply waiting for the next hand shake.
So I have switched off boiler to do some maintenance. When I switch it back on there is a red lamp lit on the receiver to say it is powered up, after some time I will get a green light to say central heating should be running.
On the transmitter there is a revolving wheel to say heat is required. But nothing to say hand shake has been done.
So I have tried switching to de-frost only, then back to normal, but still no green light on the receiver. Now with the Honeywell Y6630D Wireless room thermostat used for the bed room the thermostat flashes a red LED as it hand shakes so you know the heating should be running, if not then move the RF sender. With the Honeywell Y6630D Wireless room thermostat it is screwed to the wall anyway so I know it will work from that point.
But with the Horstmann RF Programmable HSFS1 thermostat it is free standing and doubles as a clock so it may not be in the exact point it was before when it worked. What I need is a time, if I know it takes 5 minutes between each hand shake then if central heating not running after 5 minutes I know there is a fault, does not really matter if 5 minutes or 15 minutes as long as one knows the maximum time it can take.
Has any one else had this problem if so how do they deal with it? Every time I return it is all working A1, but want to see it is working before I leave the house.
