Hi, Can anyone help?
The System
I have 14 year old central heating system:-
Glow-worm Space Saver 60BR Mk 2, fully pumped, hot water cylinder, British Gas Multi Head 2 pump (replaced Jan 2002?), Honeywell Diverter Valve F5-9738 (old?, looks like current V4044 model), Potterton EP2000 Programmer.
The Problem
The boiler fires up OK and runs for a while then cuts out (overheat thermostat?). The pipework doesn't heat up, though, at least not initially but after a couple of minutes the f and r pipework coming out of the boiler gets hot but only close to the boiler.
I can hear the pump running when switched on and hear bubbles passing through.
The box on the diverter valve gets warm when the system (ie. pump) is switched off but the power to the programmer is connected. The lever on the box of the diverter valve rests at mid-way, neither staying at the "auto" side or the "manual" side.
At the end of the last heating season the heat to the radiators used to stop from time to time. I could get it going again by switching off for a few minutes and then switching back on again (I should have done something about it then!!). Over the summer we just used the boiler for hot water and all was well.
On trying to start up the space heating recently, again not working but now it didn't respond to the switching off and on trick! Also I couldn't then get the main burner to light. I put in a new thermocouple and that got the main burner lit - but again no circulation. I noticed some minor leaks at the flow and return connections to the boiler. I drained down and fixed these, refilled the system. The current situation is that the main burner lights up OK but there is no circulation of hot water. The pipework from the boiler travels vertically up at first and then horizontally to the cylinder and pump.
My thoughts are that I have either got an airlock above the boiler or the diverter is jammed in an "off" position (if that is possible).
Many thanks to anyone who can suggest which way to go.
Regards,
Binman.
[/u]
The System
The Problem
Regards,
Binman.
[/u]
