- Joined
- 4 Nov 2015
- Messages
- 10
- Reaction score
- 0
- Country
I have recently replaced a conventional boiler with a combi one about 2.5 months ago, and was a little bit worried about leaking when changing from low to high pressure system.
And I used the 4 weeks' of holiday to test it - by turning off the mains water supply 4 weeks ago, and check if the water from tap is as powerful as it should (what I believe is, even the mains is off, the pressure from the tap should be as powerful as usual at first instance, then reduced to some level of low pressure flow).
Unfortunately when I came back today and turned the tap with mains still off, the tap flow is already low pressure, as of about 1-1.5 seconds later from what I'd expected.
I am just wondering if anyone knows it is normal, or does it means of anywhere leaking in my house that is too little or hidden to be found?
Thanks a lot!
Regards.
Thanks a lot!
Regards.
