Having dinner at my in-laws a while back, I smelt fish, which wasn't on the menu! Smelt (no pun intended) it again recently and traced it to their fuse box, which is in the same room. The "fishy" smell was actually coming from the casing of the fuse cartridge melting.
Having turned of the electricity, I needed oven gloves to remove the fuse as it was so hot. It was also looking a bit worse for wear so I replaced it with a spare cartidge. BTW, this was the 30A fuse for the downstairs ring main. Noticed this fuse soon got hot as well. Investigation shows this happens when the washing machine and (brand new) dryer are on together. If either are on separately then the fuse case is cool to the touch.
Obvious answer is not to run both together, but sometimes that is difficult. Are there any dangers in replacing the fuse with a 45A unit?
Thanks for your help...
