I am after some advice and guidance. I have an ecomax 635 hooked up to a unistor cylinder. I have a ground floor flat with 9 rads and under floor heating. System has always struggled to supply heat to last rad but has managed some warming. In trying to improve the heat from the last rad i closed down all the other rads and u/floor heating. This had some success, however i now have no heat to any of the rads. This was described as being an air lock ( vaillant engineer came to check boiler as under two years old, boiler ok). So have now bled the system several times, lots of rusty stuff but system flushing through clean now.
Each time on recharging the sytem the boiler makes an incredible amount of banging noises and will cut out with either a F23 (temp range too wide) or F24 (temp rises too fast) fault code.
Cannot get through to vaillant to ask them so thought i would offer the problem to the forum.
Any advice
Icers from Bristol
Any advice
Icers from Bristol
