I've just changed the secondary heat exchanger for a plate heat exchanger on my Worcester 280. I also changed a u/s expansion vessel as the bladder had perforated. Initial testing proved good (see previous topic!) but just found a bizzare fault when drawing hot water.
Previous topic: //www.diynot.com/forums/viewtopic.php?t=217827
Central heating seems to work fine and the pressure is regulated alot better now the new expansion vessel is in place (charged to 0.7bar before fitting). The issue arises when hot water is called for with CH off. The burner kicks in and within a minute the pressure increases like a greyhound on steroids. I knock the hot water switch off and use the PRV to stop the pressure breaking the needle (literally!)
I suspect an airlock and/or scaled primary heat exchanger but didn't have this problem before replacing parts...any suggestions welcome!!
