Just to update:
After a couple of days with X400 in the system the pump over has stopped on pump setting 1, but the water in the f&e tank is still luke warm which I'm not sure I understand. I stared at the vent for a good while and deffo no water coming from it. I then changed pump setting to 2 and water started coming out of vent again. Just for info I put my thumb over feed hole in the tank and the water stopped coming out of the vent, when I removed thumb out came the water again, no idea why i did this or why I mention it, but maybe of interest! So i guess X400 has helped clear some sludge, but will still require pipe cutting / stick poking to fix the problem once and for all!
Just to note I will be leaving the X400 in the system for a couple of weeks before flushing the system
