- Joined
- 10 Jan 2022
- Messages
- 7
- Reaction score
- 0
- Country
Hi can somebody tell me, I’m running an oil boiler 11 years old and a few months ago I noticed little green bits coming out the hot tap, and the hot water was taking longer to heat up, how ever the rads wear fine.
How ever I changed the pump because the old one was making a bit of noise.
That Warks fine then I noticed that it was staying on for 30 mins plus on the hot water side but it seemed fine in the rads.
After a bit of looking I went up the loft to see, when the water was on the boiler the pipe above the header tank had hot water coming out at some rate, so I turned the water off and just ran the rads and went for a look in the loft at the pipe again an it also had water coming out but not as fast, yes it was hot. Any ideas ?
