We've just had out combi fixed as there was no hot water and the rads got hot. The 3 way valve was repaired which has now stopped the rads getting hot when the hot water tap is on.
However, when the hot water adjuster is set to ECO (recommended setting which worked fine originally. Its a Glow worm 30ci) the gas burner comes on and heats the water but then dies down and goes out. After a few seconds it comes back on and does the same thing. This goes on forever in approx 10 second cycles. By turning the hot water temp up to nearly max (the booklet says you should only do this occasionally) the gas burner does not go out but if you watch it it starts off on full burn, then dies down (but doesn't go out now) and then flares up again. The actual temp of the water varies as the gas burner varies.
Any one any ideas?
Chris
Any one any ideas?
Chris
