This is driving me, and British Gas, crazy!!
I have a vented system with two hot water cylinders in the loft. A cold water storage tank sits above each one - they have a connecting pipe to ensure the water is level. Each CWST feeds a HWC, and also feeds the power shower. All other taps in the house are fed directly from the mains.
The problem is that hot water is going up the feed pipe into the CWST - which suggests that there must be mains pressure coming into the top of the tank. Now by my thinking, this can only be one of two things – cross over on mixer taps or a leak on the coil of the cylinder.
· All mixer taps have been checked for cross flow.
· Mixer taps downstairs are all suitable for mains pressure – the water doesn’t mix until it comes out of the tap.
· Taps upstairs have a pressure reduction valve fitted to 0.5 bar
· ALL taps have been isolated and this still happens.
· Both cylinders have been replaced over the last couple of weeks - initially BG suspected there was a leak on the coil and replaced one - didn't fix it. So the second was replaced as they thought it had a leak on the coil and the pressure was coming out of the top of that one and into the other one, pushing hot water up the feeder – still not fixed.
· New vent pipe fitted – thought that may be blocked.
Totally at a loss as to what the cause is - does anyone have an ideas or suggestions?
Thanks in advance for any assistance.
Mark
BG are coming out again tomorrow... the guy might as well move in, he has spent so much time here!!
Mark
