We recently had a new drench shower installed. All was working fine but over the last couple of days there is only a tiny bit of water trickling out.
When the temp control is turned down to cold it works fine, so cold feed is obviously working ok. The problem is we don't want cold showers and when it is at the desired heat we only get a trickle.
There is no problem with the water pressure to the bath.
Is there a quick fix? Or any other tests that can be done. Problem is the builder who installed it and did the other bathroom works failed to turn up on another job we had lined up for him and is not contactable.
