Hot water only electric???
19 Sep 2009
Hi everyone,
I am new to this topic and have a silly question
the house is about 12 years old and I have a baxi solo 2 40pf boiler in the kitchen and a hot water cylinder upstairs. It is controlled by honeywell timer thing.
It seems to me that the gas boiler only works for central heating and not hot water. Is it normal or it is somehow programmed incorrectly?
I have a quite high electrics bill for that reason
also if anyone has a manual for this equipment a link would be much appreciated as i would like to know how this system operates in the first place
please advise
There must be a motorised valve or two in or around the cylinder cupboard.
A couple of pics would help.
Is twelve years old too recent for a c plan. I'm thinking it may be a stuck ball valve or blocked cold feed.
just to say, obviously if i understood you correctly, heating is working fine and hot water is also fine, but hot water only heats up by electric heater, gas is only used for central heating so far.
i feel that gas should be used for both and electric should kick in only if necessary
or am i being thick?
