Hello
I have recently moved into a large house. The hot water and heating is powered by a Worcester Bosch 28 Cdi combi boiler. The house was renovated about four years ago and the loft space was made into bedrooms. I have had a poke around in the remaining loft spaces and eaves cupboards but haven't found a cold water storage tank.
When running the hot water for a shower, the pressure falls away if any other hot tap is turned on. The flow reduces if the kitchen hot tap is turned on, and falls away to a dribble if the other shower is running.
If all the cold water feeds are coming off the main would this cause the problem with the pressure drop on the hot feed ?
